41 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Problem rotating project to define True North- not everything rotates.
4 Posts No Rating |
I designed a multi-story building in Revit, then realized that it needed to be rotated about 120 degrees to be oriented to true north in order to have the shadows appear correctly. I tried (while in True North setting under view properties) selecting everything in site view and in 3D view, then rotating it 120 degrees, but there are a few things that refuse to rotate- the cars and some of the parking bays and a few additional objects stay in their original locations while the majority of the items do what I wanted them to. Any ideas how I can make EVERYTHING in the project rotate to what I want to make my True North be?
4 Posts No Rating |
nvm- I found the solution. I needed to use "rotate true north," which I found under "Project position/orientation" from the Tools pull-down menu. It worked.
How to Rotate True North without rotating the whole Project? |
Thu, Mar 18, 2010 at 7:25:35 PM
Project North doesn't rotate back after changed to True North |
Fri, May 7, 2010 at 3:24:14 AM
project north/true north |
Thu, Mar 17, 2005 at 5:00:19 PM
True North vs Project North Linked dwgs |
Thu, Mar 10, 2016 at 10:02:26 AM
Rotating views to project north |
Mon, May 28, 2007 at 3:46:10 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
