46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Swept Blend
Fri, Nov 28, 2008 at 5:55:50 AM | Swept Blend
R7oky
Hi i am trying to model a massing object using a swept blend, my sketch path is basically the NIKE swoosh a line consiting of 4 different arcs, i tried picking these 4 arc which i have line drawings for but get the error can not create more than one curve? What does this mean?
I also tried to over trace this path using a spline, it allowed me to create the path but then when i had done my 2 profiles at either end it would not copmplete the sweep blend.
Has anyone got any tips on how best to use the swept blend tool what i should avoid doing.
Please see attached image of my path, i will need to create 3 masses on the 3 paths in the end but i am having problems creating one at this stage.
Many thanks
Fri, Nov 28, 2008 at 4:39:26 PM | Swept Blend
4 Stars: 203 Votes
Hi, see this: http://screencast.com/t/YVxPzaWUzH
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:14 PM
cannot rotate the reference plane of a swept blend
Tue, Feb 23, 2010 at 6:22:35 AM
swept blend with more than 2 profiles
Sun, Nov 18, 2012 at 5:21:23 PM
Swept Blend for Basin
Tue, Oct 31, 2017 at 3:38:16 AM
swept blend - what am i missing???
Wed, Jul 25, 2012 at 4:49:01 PM
Page generation time: 0.9845
