54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> SHELVING SYSTEM
OKAY SO IM GETTING BETTER WITH BUILDING FAMILIES BUT THE PARAMETERS ARE CONFUSING ME. ALL i WANT IS BASICALLY A SHELVING UNIT WITH 5 SHELVES. i WANT TO BE ABLE TO ADJUST THE HEIGHT OF EACH SHELF. i WOULD ALSO LIKE TO BE ABLE TO CHANGE THE OVERALL DIMENSIONS OF THE UNIT ITSELF (HEIGHT,DEPTH,WIDTH) IF ANYBODY KNOWS WHERE i CAN FIND A GENERIC FAMILY FOR THIS IT WOULD BE GREATLY APRECIATED. OR IF YOU WANT TO TRY THIS IS WHAT HAVE SO FAR.
Have you checked the Downloads tab next to the Forums tab. Look under Division 12 Casework, there is a tall cabinet with adjustable shelves that looks like what you are looking for. If not it can be modified easily.
Attached is a tall cabinet with Adj. Sh. The shelf spacing needs to be less than the cabinet height.
thank you I added instance parameters and it worked out
Lighting in shelving units |
Sat, Nov 19, 2011 at 9:16:41 AM
Yes/No paramter controlled by two different types of paramters |
Thu, Mar 13, 2014 at 11:58:39 AM
New system type |
Thu, Sep 16, 2010 at 3:58:35 PM
Scheduling Nested Families |
Mon, Mar 9, 2020 at 11:15:10 AM
Websites for Revit Families |
Tue, Mar 5, 2013 at 5:38:47 PM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
