47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> SIMPLE SYMBOL why is it so complicated revit 2009
im trying to make an annotation to put inbetween two sections. I have tried a bunch of different ways but cant make the dimensions variable. there is a jpeg of whta im trying to make and the revit file im working on does anyone know how I could go about it?
when you make any family that is going to be parametric i always start with adding reference planes/lines then add dimensions and parameters. flex these to make sure all is working how you want it. when adding lines constrain them to the reference planes/lines. have a look at what i did to your symbol. i only did the one side. even with the ends of lines, use align to align to the ref line. hope this helps
Macca Sunshine Coast QLD Australia |
THANK YOU GUYS VERY MUCH i'M STARTING TO UNDERSTAND.
new symbol from 2009 wont load as symbol in 2011 |
Wed, Jul 6, 2011 at 2:09:39 PM
Simple Dynamic Family |
Fri, Nov 21, 2014 at 12:13:15 PM
Weld symbol editing |
Thu, Jan 6, 2011 at 9:50:16 PM
Wall hosted familes (simple question) |
Tue, Jan 15, 2013 at 2:45:24 AM
Insert North Point Annotation Symbol |
Thu, Aug 4, 2011 at 1:04:42 AM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
