65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Generic Model Materials
Hi, awhile back I created a generic model family within my project to act as facade slats that create a moire on the facade. Now, these slats are generic models, and I am having a problem making them act as wood, because now the lcient decided on what material to make them. I have tried the Object Settings technique for the Generic Models, with no success. Please help. Thanks.
Edit your in-place family. Set the material you want for the slats within the family.
You may also want to explore using a sweep to produce the slats as it might be easier to do.
HTH
Tom
the only way i can think of editting the material of the in place family would be to add a parameter. When adding this parameter, and changing the material, still no material when this inplace family is rendered.
You have to go deeper into the family. If you used a sweep for instance for each slat, you need to edit that individual sweeps material property.
This is why I suggested using the Revit hosted wall sweep instead as it makes the material assignment easier.
Tom
Generic Model Materials |
Fri, Oct 3, 2014 at 1:53:40 PM
CREATING A SCHEDULE FROM A GENERIC MODEL FAMILY? |
Mon, May 11, 2009 at 11:49:38 PM
Convert Generic Model floor based Generic -> Generic Model |
Fri, Jun 27, 2008 at 3:02:18 PM
generic model cutting issue 2016 |
Sat, Aug 27, 2016 at 7:43:47 AM
Opening in Generic Model Standing seam roof |
Mon, Aug 17, 2009 at 9:43:32 AM
Members: | 2030782 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
