61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> FAMILY HELP!
i HAVE TWO PROBLEMS TODAY. FIRST IS A CUBICLE. i NEED TO MODIFY THIS CUBICLE TO MAKE IT LIKE THE JPEG WITH VARIABLE PERAMETERS. i'D APRECIATE ANYONE WHO COULD HELP. ALSO THE SECOND PICTURE IS A COUNTER TOP FOR A SPECIFIC APPLICATION DOES ANYINE KNOW A WAY TO MAKE THE VALUES ADJUSTABLE i HAVE ENCLOSED THE CUBICLE RFA BUT CAN'T FIND A GOOD ONE FOR THE COUNTER. ALSO IM STILL A NOOB WHENIT COMES TO MAKING FAMILIES DOES ANYBODY KNOW A REALLY GOOD SITE OR PDF TO LEARN HOW THANKS IN ADVANCE
your nearly there on the first one. either add in visible parameters to turn the glass on and off. or if you're feeling keen use some conditional formatting... Use a void to 'cut geometry' on the solid for the counter type. You may need to employ a bit of trig to get 'y'. So make a triangle that cuts into the counter surface. there is a really good family guide released by Autodesk. there is also plenty of reading to do here. Keep at it!!
The problem was that you modeled the Panel from the top and gave it a height. You should have modeled it from the front and gave it a thickness. I will try to do the top later tonight.
Top attached
THANKS A MILLION.
No problem. I thought you might be intrested in some free cadclips in the basics of creating a revit family. Go to this link and download the 7 video tutorials they are a good place to start. http://www.dgcad.com/REVIT-AC-2009-BeamFamily.htm
you guys don't know how much apreciate this. as soon as i'm at your level I will give as much advice as can long live revit
Create a family that includes another family |
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family? |
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message |
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3 |
Mon, Jan 19, 2015 at 2:43:21 PM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
