Forums >> Revit Building >> Technical Support >> Plan Region & stairs
16 Posts No Rating |
Using RAC2009 I have a set of stairs that starts on a platform 35" above level 1. I have been trying to get the stairs to show more tread/risers before it cuts off (right now, it is only showing 2). I have read that you can create a Plan Region around the stairs, and it will allow you to set the cut planes to the level of the platform. I have done this, but I cannot get the stairs to show a different cut plane than one used by level 1. Here are the view range settings I have tried to use. top: Platform Offset: 7'6" Cut plane: Platform Offset: 4'-0" Bottom: Platform Offset: 0'-0" View Depth Level 1 Offset 0'-0" Do I have to somehow attach the stairs to the plan region? is there a toggle I am missing? Is there any other way to force the stairs to cut at a different height?
I don't understand. Did you create another level called platform offset? The plan region should be aroud the stairs & the view range can then be set from the level 1.... cut plane level 1 + 8'??? that puts it 5' +/- above your platform....
no, the level is called 'Platform' look at it as 3 columns: Top: Platform Offset: 7'-6" etc... I have tried moving the refered levels, cut planes etc... nothing, and I repeat nothing seems to affect the cut plane of the stairs (yes, the stairs are fully enclosed in a plan region).
here are two different screen shots, showing 2 completely different cut planes (note that the door cut correctly, but the stairs didn't change at all).
I have been experimenting, here is what I have found. #1) If the plan region is drawn at any other angles than 0, 90, 180, 270 the stairs will not cut with the plan region. #2) If the plan region touches the stairs at any point, it will not cut (this includes the text 'dn' & 'up') So, with these two MAJOR bugs I am SOL on changing the cut plane for my stairs.
I've found that stair breaklines can be changed only for stairs starting at the reference level going up. View Properties --> View Range --> Cut Plane: Setting the Cut Plane to 3'-0" for example, would show about 4 full treads for 7/11 stairs. Setting the Cut Plane to 5'-0" for example, would show about 8 full treads for 7/11 stairs. One would think that for a run of stairs starting at the reference level and going DOWN, that the "Bottom" and "View Depth Level" settings would have a similar impact on a breakline for the DOWN stairs. It appears that the entire run will show up regardless of what the view depth and/or bottom settings are. See attached.
No - plan regions work in both directions but as rgordon posted - if the plan region is rotated, you have problems.
I've been messing with the plan region. The best that I can seem to do is to get the "down" stairs to look like stacked stairs. See attached.
Rotation of plan region and moving to just barely touch doesn't change the view of the stairs. See attached
Plan Region |
Fri, Jul 21, 2006 at 4:23:10 PM
Stairs and plan regions (cut height) |
Mon, Apr 21, 2014 at 10:22:57 AM
Plan Regions Cutting Stairs |
Thu, May 26, 2011 at 6:14:12 PM
plan region view representation re: stairs |
Mon, Mar 2, 2009 at 1:07:14 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary |
Tue, Jun 23, 2009 at 4:46:32 PM
