Forums >> Revit Building >> Technical Support >> Cont. Footing Question
1 Posts No Rating |
I need to have a continuous footing at the bottom of a thickened slab edge. Is there anyway to add a cont. footing without the use of a wall? Or maybe another way that i can accomplish this. Thanks
2 Posts No Rating |
I have this same issue as well! It won't let me move the footing to below the thickened slab edge.
make another sweep in the shape you want, use the 3d view to pick the edge you want it to run. make it a component model...as a foundation.
2 Posts No Rating |
Thanks!!!! (I'm very new to this!)
Most people place a concrete foundation wall and join that with the slab. The wall footing will work under that. If you need to, just make the wall very short.
I also have a "stacked wall" defined, where the footing is like a 16" wide wall, only 8" hi, and another 8" wide variable height stem wall on top of that. lets you make "T" footings anywhere with the wall tool.
Continuous Wall Footing ? |
Thu, Aug 23, 2012 at 1:59:48 PM
13
another footing question |
Mon, Mar 10, 2008 at 6:53:36 PM
Rebar in Stepped Footing |
Mon, Dec 7, 2009 at 9:21:17 PM
Footing tool! |
Mon, Apr 2, 2007 at 11:26:27 AM
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:14 PM
Members: | 2115718 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
