111 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> grid lines question revit 2009
Tue, Nov 25, 2008 at 9:50:38 AM | grid lines question revit 2009
paulykustomz
paulykustomz Avatar
when I make a grid it works fine and I can see it in in all views. my problem is when I stretch a gridline so it works in a drawing i have no problem but if a switch floorplans the grdline is in the original location and I have to move all of them. is there a way that when i adjust a gridline it stays the same? do you have to adjust every floor plans grid?
2nd question
when I move gridlines horizontally (changing span) my dimensions do not change accordingly is there a way to make them do so... like basically locking them to the grid?hank you in advance.
Tue, Nov 25, 2008 at 10:08:54 AM | grid lines question revit 2009
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You should be able to select the grid and click "Propagate Extents" button at the top. This will allow you to select specific views to match the extents.
Tue, Nov 25, 2008 at 11:02:15 AM | grid lines question revit 2009
KingRevit
4 Stars: 12 Votes
you can also selt grids rt.click and maxamize 3d extents but this give you less control than james's way
Tue, Nov 25, 2008 at 12:03:28 PM | grid lines question revit 2009
tim123
4 Stars: 19 Votes
Also if you click on the grid lines they show a 3d or 2d button.  If this is set to 3d it will change in all views.
If you dimension to the actual gridline then the dimension should change when you move it.
Grid line for Revit Architecture 2009
Wed, Mar 24, 2010 at 8:21:54 PM
grid lines extend beyond detail
Mon, Jul 20, 2009 at 2:06:01 PM
Revit 2009 - Grid and Level lines obscure model elements
Fri, Sep 12, 2008 at 4:00:59 AM
Grid Lines - Instance based text in grid line family
Mon, Jul 23, 2018 at 2:17:15 PM
Break Grid lines
Sun, Jul 18, 2010 at 9:36:16 AM
Page generation time: 2.2225
