122 Users Online (121 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> BRING TO FRONT COMMAND FOR REVIT?
Mon, Nov 24, 2008 at 4:13:04 PM | BRING TO FRONT COMMAND FOR REVIT?
paulykustomz
paulykustomz Avatar
IF I HAVE AN ANNOTATION ON AN ELEVATION IS THERE A BRING TO FRONT COMMAND SIMILAR TO AUTOCAD. i HAVE TROUBLE TO SEE THE ANNOTATION SO CAN i MAKE IT STAND OUT MORE OR MAYBE LEAVE AN UNHATCHED REGION?
Mon, Nov 24, 2008 at 4:29:10 PM | BRING TO FRONT COMMAND FOR REVIT?
tim123
4 Stars: 19 Votes
You can set the background of text to be opaque or transparent in its properties.
Mon, Nov 24, 2008 at 4:39:22 PM | BRING TO FRONT COMMAND FOR REVIT?
afc4
3 Stars: 3 Votes
There is only a Bring to front for detail components in revit. You could make the background of the text opaque so it masks out whats behind it.
Tue, Nov 25, 2008 at 9:43:42 AM | BRING TO FRONT COMMAND FOR REVIT?
paulykustomz
paulykustomz Avatar
thank you very much for you quick replies
but now I wonder if I change the text on one of my elevations will it change it on all of my elevations or just that one? because the other ones need a transparent background.
Tue, Nov 25, 2008 at 10:40:32 AM | BRING TO FRONT COMMAND FOR REVIT?
afc4
3 Stars: 3 Votes
Text is view specific. if you want to change all of it, Rt. Click on one of the text boxes and select all instances. That will select all the text in you project of the same type.
bring to front command in Revit MEp 2012
Tue, May 24, 2011 at 1:39:40 PM
Bring To Front
Thu, Mar 5, 2009 at 12:54:53 PM
BRING TO FRONT/SEND TO BACK
Fri, Dec 9, 2011 at 7:58:01 AM
dwg import bring to front
Fri, Jun 27, 2008 at 9:46:56 AM
bring to front/send to back?
Fri, Jun 7, 2013 at 7:47:02 AM
Page generation time: 3.0404
