Forums >> Revit Building >> Technical Support >> Change mass colour for massing study
5 Posts No Rating |
Hi everyone, I need to create a massing study for my design and ive begun creating some masses. However, I can't figure out how to change the color (if you can actually do it), for now theyre all a studid pink/purple color. Any help would be appreciated. Thanks
Hi, pick in the "mass" and pick "Edit" because probably you create several mass at the same time, when you "Edit" you can select one by one and you can go to the properties of each other and duplicate the name and change the material and color individualy, in VG-Model category-Mass you can change the properties for all the mass in the view but i think this is not what do you need/want....
5 Posts No Rating |
Hi thakns for the reply Ty, However it doesn't seem to be working. I understand how material properties work for other elements but when i go to the mass' properties I'm unable to change the colour. It doesn't allow me to duplicated the forms of any sort either.
So, when you edit the Mass pick in one of them and pick "edit", the magenta lines appears, there go to the properties and in "material" you have on the right side a button "..." pick and "Add a Parameter", do it in all the mass you have (e.g.: mass1 mass2...), so in this way, you have several Mass materials in your Material Editor....
Massing Studies with Multiple Buildings with different levels |
Sat, Apr 28, 2012 at 2:32:46 AM
Free Video - Parametric Massing Study |
Fri, Nov 27, 2009 at 11:22:14 AM
Design a apartment, should start from mass study or walls |
Mon, Aug 23, 2010 at 4:44:43 PM
change colour/material of a beam |
Sat, Dec 10, 2011 at 12:06:56 AM
how to add an edge in an conceptual massing |
Sun, Jul 24, 2011 at 2:36:44 AM
Members: | 2099035 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
