Forums >> Revit Building >> Technical Support >> LEADER
50 Posts No Rating |
i would like to use a leader with arrows but without text attached . is that possible?
Create a blank text type then add a leader to the blank text...
OR create an adjustable annotation for the leader and place as a symbol...
thanks Mr. Spot
how do i create a blank text? and adjustable annotation?
could you elaborate. a step by step approach would be helpful
I don't actual have the blank font type, if you do a search on augi you should find it somewhere though.
For the adjustable annotation (which is the method we use) its a matter of starting a new generic annotation family with instance parameters to control the arrow length, head size, angle etc.
If you created any families before its a fairly easy thing to do. Ours is actually a detail component which basically means it will scale with the view where as a symbol is always the same size regardless of view scale.
I'll attach if need be.
46 Posts No Rating |
Mr. Spot, Not that great with families yet - I should be! Although it was almost 4 years ago, I know you are on here a lot - would you mind attaching the blank leader you mentioned in the previous thread? I downloaded one from here, but I unable to find a way to change the size of the arrow head. It stays at 1/8" regardless. I would greatly appreciate it - thanks! Boyd
Multiple Leader Text |
Sun, Nov 18, 2007 at 12:33:40 PM
Adding Snaps to Leader Lines |
Thu, May 29, 2014 at 7:34:34 AM
Leader Question |
Thu, Jun 16, 2016 at 12:24:28 PM
Positioning the leader on a tag. |
Thu, Aug 6, 2015 at 12:16:39 PM
leader lines |
Mon, Jan 19, 2009 at 2:39:06 PM
Members: | 2119072 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
