137 Users Online (134 Members):
Forums >> Revit Building >> Technical Support >> Variable height horizonatl wall sweeps
4 Posts No Rating |
I am trying to create a wall sweep for horizonatl seam metal siding. I began by creating the profile of a single panel and applying as a sweep in the wall section view of the assembly editor, which results in only a single panel at the base of the wall. Is there a way in which I can make the height of the panel profile variable so that it is tied to the height of the wall, covering the entire surface? Any suggestions will help. Thanks.
You can set heights to the sweeps in the editor and add more at different heights either from the top or bottom of the wall. A better solution may be to create the panel as a curtain wall panel and create the wall using curtain walls.
Reveals & Sweeps Variable Height |
Wed, Aug 20, 2008 at 2:53:17 PM
Stacked Wall Problems |
Wed, May 18, 2016 at 9:10:52 AM
why do wall sweeps define the wall height? |
Fri, Mar 6, 2009 at 12:57:04 PM
wall sweeps won't clean up |
Fri, Jul 11, 2008 at 2:52:46 PM
Angling Wall Sweeps |
Members: | 2030612 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
