74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how I do a render of a plan - orthogonal ????
Fri, Nov 21, 2008 at 6:44:22 AM | how I do a render of a plan - orthogonal ????
querosaber
how I do a render of a plan - for example a ground floor or a roof plan?
 orthogonal
 thanks a lot
Fri, Nov 21, 2008 at 6:54:13 AM | how I do a render of a plan - orthogonal ????
rossaftermath
5 Stars: 5 Votes
you mean like this?
Fri, Nov 21, 2008 at 8:23:21 AM | how I do a render of a plan - orthogonal ????
querosaber
yes , exactly, i tried witd 3d viws , but dont make so perfect.
I apreciate you tell me how you can do this !( looks really nice)
thanks
Fri, Nov 21, 2008 at 9:17:25 AM | how I do a render of a plan - orthogonal ????
querosaber
 i fouud a similar thread .
 answer
http://www.revitcity.com/forums.php?action=viewthread&thread_id=5641
started by  hjacobs..
 thanks...
Fri, Nov 21, 2008 at 9:20:12 AM | how I do a render of a plan - orthogonal ????
rossaftermath
5 Stars: 5 Votes
No problem..
first of all.. you need to duplicate your 3dview/ {3d}
Then with the new "copy of {3d}" open go to View options menu at the top of the screen, so its
So..
view>
orient>
to other view>
then select your floor plan or roof plan ,
then you'll be be able to access your render option as well.
let me know if you need anymore help
Ross
Thu, Dec 1, 2011 at 10:12:26 AM | how I do a render of a plan - orthogonal ????
AlphaOjo
Hi rossaftermath,
Thanks for the post, but is it possible to render a view that is NOT in perspective, like the one you showed?  I can orient the camera to different views - elevation, section, plan, etc. - but they are all perspective.  Please help!
 Thanks.
Thu, Dec 1, 2011 at 10:36:39 AM | how I do a render of a plan - orthogonal ????
Click on the house (3D) icon.  Now click on the top of the box and render this view.  If you need a plan, use a scope box.
Thu, Dec 1, 2011 at 10:50:46 AM | how I do a render of a plan - orthogonal ????
AlphaOjo
Great.  Thanks!  I guess what wasn't clear to me was the different between camera views and the ONE default 3D view.  I didn't realize they were different, even after a year of using Revit!
How to render any orthogonal view
Wed, Jun 25, 2008 at 9:16:17 AM
How do you render a 2D floor plan???
Thu, Dec 3, 2009 at 2:26:14 PM
Deleting Perspective When Rendering
Wed, Nov 30, 2011 at 1:08:19 PM
4" X 24 " orthogonal Herringbone Pattern .pat
Sun, Oct 20, 2019 at 7:46:08 AM
Arcs and non-orthogonal geometry
Wed, Dec 28, 2005 at 9:49:47 PM
Page generation time: 1.1537
