92 Users Online (91 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> sectional perspective TO SCALE
Thu, Nov 20, 2008 at 8:11:58 PM | sectional perspective TO SCALE
eahager
I'm trying to create a sectional perspective to a particular scale--I've read most of the posts on sectional perspectives. Any suggestions?
Fri, Nov 21, 2008 at 11:30:57 AM | sectional perspective TO SCALE
There is never a scale to a perspective since all items diminish with depth away from the viewpoint.
Fri, Nov 21, 2008 at 12:06:50 PM | sectional perspective TO SCALE
eahager
I realize that a perspective can't be scaled. I would like the section part of it to be to a particular scale, i.e. to be able to set the scale at the cut line.
Wed, Feb 11, 2009 at 1:29:41 PM | sectional perspective TO SCALE
squaresquire
I too am interested in creating a section perspective in which the section cut is set to a scale, and the rest of the building is in perspective. Any suggestions would be very much appreciated
Thanks
Wed, Feb 11, 2009 at 3:13:36 PM | sectional perspective TO SCALE
tim123
4 Stars: 19 Votes
As WWHub sugests, a section can not be to scale.  If your camera view is perpendicular with the view you could eyball it, as you could adjust the size of the image.  Of course this will never be totally accurate as the width and height would vary depending on the camera position.
Wed, Feb 11, 2009 at 3:14:30 PM | sectional perspective TO SCALE
wheelergc
The only way i know is by using photoshop.  Export a regular section cut, then export a sectional perspective.  Then use photoshop to scale the sectional perspective.
Sectional Perspective NOT cutting in the N,S,E and W direction
Mon, Oct 3, 2011 at 2:29:47 PM
help! how to create a sectional perspective??
Tue, Nov 22, 2016 at 7:12:43 AM
11
Sectional perspective with lighting question
Tue, Nov 23, 2010 at 9:08:07 PM
Rendered Sectional Perspective Cut
Tue, Jan 25, 2011 at 7:25:54 AM
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
Page generation time: 0.3530
