84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> OCCUPANT LOAD FROM CALCULATED VALUE/IF STATEMENT
Thu, Nov 20, 2008 at 10:54:34 AM | OCCUPANT LOAD FROM CALCULATED VALUE/IF STATEMENT
CAPTAIN25
i'm attempting to write a formula to automatically calculate the occupant load for a particular space.  what i want the formula to do is to recognize the number in one "cell" and to respond in another "cell" according to what it reads.
in other words (see attached)
if comments = 15 then divide the area by 15if not then...if comments = 20 then divide the area by 20if not then...if comments = 100 then divide the area by 100
i've read about how to write the syntax for a conditional statement with embedded IF statements and i thought i understood it (similar to excel) but i keep getting the error that reads "improper use of boolean expressions."
this is the formula i'm using:
IF(Comments=15, Area/15, IF(Comments=20, Area/20, IF(Comments=100, Area/100,0)))
what am i doing wrong?  is what i want possible?
Fri, Nov 21, 2008 at 11:42:15 AM | OCCUPANT LOAD FROM CALCULATED VALUE/IF STATEMENT
You may want to check out these threads ;  the last one may be the closest to your needs
http://www.revitcity.com/forums.php?action=viewthread&thread_id=6668
http://www.revitcity.com/forums.php?action=viewthread&thread_id=7562
http://www.revitcity.com/forums.php?action=viewthread&thread_id=4556
http://www.revitcity.com/forums.php?action=viewthread&thread_id=10228
occupant load factor
Fri, Oct 14, 2011 at 10:31:09 AM
Help with If then statement [ 1 2 ]
Tue, May 5, 2009 at 2:19:11 PM
17
Occupant Load Factor Tag
Thu, Feb 10, 2011 at 8:34:43 AM
Rounding Issue in Schedules
Mon, Jan 9, 2017 at 11:55:44 AM
Calculating occupant loads using room schedule
Wed, Mar 7, 2007 at 4:45:13 AM
Page generation time: 0.4063
