83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> line patterns
50 Posts No Rating |
how do i upload line patterns into my line type selector
for instance i have hidden lines but there are other scaled variations of hidden lines which don't show up
when i go to detail lines and the type selector drop down list appears
thx
Create new Line Patterns by going to Settings-->Line Patterns--> Then use lines and spaces in order to get the appropriate line.
To create new Line Types using this line pattern. Go To Settings-->Line Styles then create a new line type under the category of lines then select its pattern to the one required.
All lines located in here that are not used for system properties will be able to be drawn using detail lines.
HTH.
Associating Line styles with patterns |
Tue, Sep 18, 2012 at 11:30:05 AM
Tile Patterns, not line patterns |
Fri, May 17, 2019 at 9:29:04 AM
Deleting multiple line patterns... |
Mon, Nov 2, 2009 at 11:18:30 AM
Line Patterns |
Tue, Aug 9, 2005 at 3:08:30 PM
Line Patterns - Too restrictive |
Fri, Oct 7, 2005 at 4:50:38 PM
Members: | 2017008 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
