34 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Section Head
Thu, Nov 20, 2008 at 12:10:50 AM | Section Head
EssG
Hi..need some help.
 I need to move a "section head" so that it does not conflict with dimensions on a working drawing Floor Plan. On two of the levels there is no problem shifting it to the best position but on the 3rd level for no reason when pulling the yellow dots toward the head, the head kicks out at a 90deg angle and wont move further up.
Any advice on how to stop it doing this ??
Thank
Essie
Thu, Nov 20, 2008 at 12:16:08 AM | Section Head
EssG
Sorry..using Arch 2008
Fri, Nov 21, 2008 at 12:03:45 AM | Section Head
EssG
Still looking for an answer!
Fri, Nov 21, 2008 at 3:54:21 AM | Section Head
4 Stars: 203 Votes
Hi, can you put some images to figure out what is happen?
Fri, Nov 21, 2008 at 4:45:48 AM | Section Head
EssG
Thanks for your help.....
I'm happy to  put an image up, but how would I do that..the project is 32MB so I cant attach the whole file?
Fri, Nov 21, 2008 at 5:09:36 AM | Section Head
4 Stars: 203 Votes
I don't want the file, only images, pictures of the problem, in the plan view (or elev, section...) you can go the "File-Export-Image" then you can create a image of that plan view you are working, or you can use external programs to capture video/images like "JING", there are several...
Fri, Nov 21, 2008 at 5:23:38 AM | Section Head
EssG
Ok here they are..The section head that is doing it is section B. On the first image the section leg is going through my dimensions. when I try and pull the yellow dot up to the head to shorten it  it kicks to the side as in the second Image
Trying to Import Filled Section Head
Mon, Jun 27, 2016 at 2:32:46 PM
problem with section head
Sun, Nov 26, 2006 at 4:49:06 PM
Section Head
Thu, Nov 11, 2010 at 2:21:52 PM
Section Head
Tue, Jun 18, 2013 at 11:22:53 AM
Section Head with Typical
Tue, Jan 29, 2019 at 8:18:28 PM
Page generation time: 0.7090
