79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Fixed Reference Point
Tue, Nov 18, 2008 at 5:35:37 PM | Fixed Reference Point
jgecan
Is it possible to create a fixed reference point which will not move under any circumstances?
 I am working with a very irregular column grid which is not aligned on the horizontal and vertical.  The architect has the building rotated in plan such that I need to provide radial constraints to Gridlines.  I have been locking constraints on the Gridlines, but with the radial conditions, I've found that my entire Grid gets rotated by some very tiny number of degrees.  Even when everything is constrained, I cannot prevent the entire model from "spinning" slightly in plan.
Wed, Nov 19, 2008 at 11:02:36 PM | Fixed Reference Point
cganiere
cganiere Avatar
Put something there and then "pin" it. It won't move unless "unpinned.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Reference Point Hosting Problem
Fri, Jan 31, 2014 at 4:53:39 PM
EQ Dimensions and Fixed Distances
Wed, Nov 27, 2013 at 1:26:37 PM
View Reference center point is too far from the label.
Wed, Nov 19, 2014 at 9:24:14 AM
Reference Points that have Normalized Curve Parameter
Tue, Jun 3, 2014 at 4:15:15 PM
Allow 3 point Definition for Reference Planes
Mon, Mar 28, 2005 at 8:53:53 PM
Page generation time: 1.6386
