68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Templates
Tue, Nov 18, 2008 at 1:28:00 PM | Templates
SteveB
3.5 Stars: 5 Votes
after having worked for a while on a drawing file, is there a way to save all the stuff from transfer project standards, plus all the loaded models, drafting details etc, views:  in other words everything except the building model to a template.  The way I do it now is to have to delete everything that is drawn, then save to a template.   If you save the drawing to a template, best I can tell, you just get the same building file ready to be renamed something new.  Same as "saveas" a different name
Tue, Nov 18, 2008 at 1:34:09 PM | Templates
4 Stars: 203 Votes
yeah, delete all what do you don't want and "Save as", in "Files of type" choose "Template files *.RTE" and go to your template folder, give the name and save, if you want to start with that RTE, go to "Settings-Options-File Locations-Default Template File" and choose the new template you are just created...
Tue, Nov 18, 2008 at 1:38:46 PM | Templates
SteveB
3.5 Stars: 5 Votes
seems clunky.  You are left trying to undo all the revision clouds (if issued, you can't delte them and chasing down every detail item and line you've drawn in every view to delete.  Ouch.
Tue, Nov 18, 2008 at 6:28:04 PM | Templates
mtyp
it is gonna be a bit messy too doing it that way.  It works but maybe you should consider doing it manually by transferring project standards, loading families, etc.
This way you'll end up with a cleaner template file.  Then save as and change to RTE.  Basically doing in the manual manner will let you make decisions about what you actually need and reduce your template file size.
Wed, Nov 19, 2008 at 4:01:43 AM | Templates
4 Stars: 203 Votes
Yeah, it's true...
Where have my templates gone in 2012
Sat, Apr 7, 2012 at 9:09:06 AM
Family Templates
Tue, Nov 26, 2013 at 9:56:21 AM
Drawing templates
Thu, Jun 10, 2004 at 1:41:36 PM
lineweight templates for optimal appearance
Tue, Jul 7, 2015 at 1:58:11 PM
Used based Revit templates
Fri, May 2, 2014 at 5:17:38 AM
Page generation time: 0.2105
