60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> How to change material properties of a mass
1 Posts No Rating |
Hi All: I am very new to Revit. I have created a solid shape in Rhino and created a new mass family with this shape by importing it as a DXF. I've inserted the new family into my project and I would like to now change the properties from a general mass object to a concrete object. Also, is it possible to manipulate this object's dimensions in Revit? Any help is greatly appreciated. Please see attached image.
Hi, when you import the object to revit you can attach floors, roofs, walls and curtain system, what do you import from Rhino is only an object (ACIS solid), you can't edit them or manipulate that object (edit/properties only the import units, scale factor and little more than that), that image you post are very simple to do in revit....
32 Posts No Rating |
Which version of revit your using??? in version 2009 you have lot more options for massing.You can goto these sites where you can learn from basics. www.revittut.blogspot.com www.revitoped.com www.reviteer.com
making in-place mass solid/"real"? |
Tue, Nov 22, 2011 at 12:40:25 PM
Reverting a mass to material <by category> |
Thu, Jun 14, 2018 at 3:18:10 AM
change curtain by pattern system material |
Wed, Sep 1, 2010 at 2:49:21 PM
Mass Material Problems |
Mon, Sep 19, 2011 at 4:59:18 PM
How To Change Railing Materials |
Thu, Jul 9, 2009 at 2:54:23 PM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
