79 Users Online (78 Members):
Forums >> Revit Building >> Tips & Tricks >> Is there a way to query a linked model's element?
2 Posts No Rating |
Is there a way to query a linked model's element? I am trying to identify the object by hovering the mouse + TAB on the linked architectural model, but the status bar would only tell me "RVT Links : Linked Revit Model : filename.rvt : 1 : location <Not Shared>" It would not list more information by hitting TAB. I want to be able to identify the objects in the linked model, such as wall type, door type, window type, and etc. Thanks
![3 Stars: 3 Votes](/images/stars_3.gif) |
When you tab through and select an element make sure that you click on it so it turns red. In the type selector you will see what type of object that it is. The only thing is that you wont be able to edit the element.
![Lochnesska Avatar](user_avatar/262107.jpg)
When you click on the DWG import, on the right in the menu there is a symbol like Layers in AutoCAD with a blue "i" called "request" (I think, don't using the english version - this layout is in Revit 2011). You click on that and then click on the line or text you want to know on which layer they are. Nevertheless you'll never be able to identify them directly as revit families.
Nessie
Revit 2013 |
Is there a way to query a linked model's element? |
Mon, Jan 30, 2012 at 7:58:01 AM
Query regarding Linked Structural revit model |
Mon, Apr 8, 2013 at 7:23:44 AM
Can't select the linked model |
Mon, Aug 4, 2014 at 1:06:26 PM
Levels in linked files |
Tue, May 24, 2016 at 9:40:38 AM
linked revit model disappears when I edit a floor or do an 'in place' model |
Mon, Dec 17, 2012 at 8:01:15 PM
Members: | 2017373 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
