96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> transfering roof sweep profiles
41 Posts No Rating |
Can anyone shed some light on my roof sweep dilemna? In creating roof sweeps (fascia) I want to be able to reuse those profiles in other projects, but I also want the ability to trace to profile over the roof edge. If I go with an in-place create family, edit sketch profile, I can't save the profile for reuse. Is there anyway to transfer it to another project? If I create a new "hosted profile" to solve that problem, I can't figure how to draw it on top of the roof geometry (as a guide).
![3 Stars: 10 Votes](/images/stars_3.gif) |
Hi, From File Menu, Click Transfer Project Standard. You have to have the 2 projects open. You can also save your profile to your library and load it to your new project.
Motto: "No Post left behind" |
Thanks. I knew it would be something easy and obvious.
Sweep Profiles in Version 9 |
Thu, Aug 3, 2006 at 2:14:05 AM
Wall Sweep/Siding up to Roof Line |
Fri, Nov 23, 2007 at 11:09:49 AM
Multiple Profiles in a Sweep |
Fri, Nov 2, 2007 at 6:02:35 PM
Loading Roof Fascia profiles |
Thu, Feb 1, 2007 at 5:16:55 PM
Blend sweep problem |
Tue, Feb 28, 2012 at 1:51:35 PM
Members: | 2017294 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
