51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window and door objects required
Fri, Nov 14, 2008 at 5:19:03 AM | Window and door objects required
armour35
Hi first post, im doing my first house project in revit after doing it in archicad. Got to say Revit is much better than archicad for producing the model in a clear logical layout.
I need a patio door and side lights plus a different front door style to the type used in revit. I attach a elevation to show what im after and any guidance from you guys would be greatly appreciated.
Fri, Nov 14, 2008 at 6:58:29 AM | Window and door objects required
You can modify one of the door with side lites families to do what you need.  No time like the present to learn how!
Goto some of the links that have tutorials on family building, then if you have problems, come back with more specific questions.  Be sure to use your HELP and search this site first though!
Fri, Nov 14, 2008 at 7:18:51 AM | Window and door objects required
armour35
WWHub many thanks for your reply, will have a go at tutorials like you say and come back if i need any further help
cheers!
Door and Window Scheduling - showing the door and window as an image.
Thu, Feb 11, 2016 at 7:50:52 AM
Change objects' properties
Sun, Feb 28, 2010 at 8:51:45 PM
11
Door and Window types
Thu, Nov 23, 2017 at 11:19:53 AM
What type of window are these????? HELP~~
Sun, Feb 19, 2012 at 2:47:54 AM
Need help tagging/scheduling a door with a sidelite
Tue, Jun 8, 2010 at 2:15:23 AM
Page generation time: 1.0930
