35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Windows/ Doors between floor levels....
Thu, Nov 13, 2008 at 1:33:45 PM | Windows/ Doors between floor levels....
Shnail
Hi, I have a peculiar problem, and am hoping someone out there has a work around, or solution for it.
I have included a picture to demonstrate a little clearer the problem. I have a set of stairs that go up 6 risers, and turns 90 degrees, i want to put a window in the wall where the landing is, the problem is, that the window extends up and into the 2nd floor wall, but doesn't cut out the wall like a window normally does. My current work around is to insert a replica window into the second floor wall, and align the window to the main floor window. Which if i didn't use schedules would be alright. But in the schedules there are multiple tags for the same window, so i just give one of the windows a 'N/A' and hope the contractors don't include that window in their orders....
thanks for any suggestions, and solutions.
Tim
Revit user since 2008.
Thu, Nov 13, 2008 at 2:24:00 PM | Windows/ Doors between floor levels....
mhans
3 Stars: 10 Votes
Hi,
 Have you tried adjusting your view range to include that window in the desired level? I also would do a window family that has some ways to tell Revit that whenever the cutplane is within the two lines (above & below see image), that window should show on that plan.
Motto: "No Post left behind"
Thu, Nov 13, 2008 at 2:45:40 PM | Windows/ Doors between floor levels....
tim123
4 Stars: 19 Votes
Check that your walls are in the same plane, as the window should cut both.  Draw a section through the walls to check.  Try and join hte walls - use join geometry.
Thu, Nov 13, 2008 at 4:17:29 PM | Windows/ Doors between floor levels....
coreed
coreed Avatar
4 Stars: 16 Votes
just use a plan region in that area at the second floor level and set the cut plane to intersect the window below.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Nov 17, 2008 at 4:33:57 PM | coreed
Shnail
Quoting coreed from 2008-11-13 16:17:29
HTH
i will give this a go, like i stated before, i am trying to get the window to cut through the wall above.
thanks
How do I sort my count of doors/windows as per levels horizontally in schedule?
Thu, Sep 24, 2020 at 2:53:16 PM
Excluding doors and windows in count
Wed, Feb 15, 2006 at 2:59:05 AM
Doors and windows do not show up on the 2nd floor
Sun, Nov 25, 2012 at 12:23:18 PM
My self created doors and windows do not show up properly in my floor plans
Fri, Jun 30, 2006 at 1:28:19 PM
Editing & Drafting with floor levels Revit 2012
Fri, May 3, 2013 at 8:05:58 AM
Page generation time: 0.7362
