58 Users Online (57 Members):
Forums >> General Discussion >> Revit Project Management >> Cut planes
8 Posts No Rating |
Can individual wall or any object for that matter have its own cutplane in a given view or is based only on the views cut plane. Thanks for the help.
Hi, Not sure what you mean. Cut plane is always parallel to the view and all object that passes through this plane are cut at the same level. if you are thinking of a jagged cut plane like a section cut on plan, then you have to do some 'tweaking'.
Motto: "No Post left behind" |
I am not sure this is what you mean but you can do a plan region around a certain object such as a floor drain or window without changing the level's view range.
8 Posts No Rating |
Thank you for the help
Cut Planes for CMU Bearing Wall Systems |
Thu, Jun 4, 2009 at 6:08:28 PM
make elevation cut line show from diffrent planes |
Thu, Jul 9, 2009 at 2:10:05 PM
Shadows & Cut Planes |
Wed, Jun 15, 2011 at 12:24:13 AM
Listing the Abilities of Reference Planes |
Sun, Sep 9, 2012 at 9:24:07 PM
Windows & cut planes |
Fri, Aug 10, 2007 at 3:24:30 PM
Members: | 2056191 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
