Forums >> Revit Building >> Technical Support >> LINKING DRAWING INTO MOST RECENT TEMPLATE
160 Posts No Rating |
RA 2008 Have reactivated a drawing that's about 12 month old. My template has progressed quite a bit since we stopped working on the drawing in question. I opened up a new project to activate a drawing that has the most recent template in it. Deleted all content used "import/link" to pull in the reactivated revit file. thought it was unusual that I could select a few individual items like roofs, while in the same view I could also select the entire project. Actually did delete the entire project on purpose. First time trying to update an older drawing into the most recent template. A little confused if I'm on the right track. Any thoughts?? Thanks in advance.
Go the other way.... purge unused first than transfer project standards from template to project.
THANKS I NOTICED THAT THE DETAILS FROM TEMPLATE DRAWING DID NOT TRANSFER. I HAD ROOF PITCH SYMBOLS AND A LOT OF STANDARD NOTES SAVED AS DETAIL GROUPS. IS THAT NORMAL? GENERALLY ANYTHING ELSE I SHOULD CONSIDER WHEN TRANSFERRING STANDARDS? AS A MATTER OF NOTATING YOUR DRAWINGS, DO YOU ALSO STORE NOTES AND SYMBOLS AS DETAIL GROUPS?
DOORS AND WINDOWS ALSO DIDN'T TRANSFER???
Details are no problem. Just File/Insert from file/Views and pick all of the views to transfer. You can also cut & paste other missing items.
Edited on: Fri, Nov 14, 2008 at 6:09:25 AM
LOGO in drawing template |
Fri, Dec 1, 2006 at 10:38:45 AM
Linking ADT imports |
Tue, Apr 24, 2007 at 3:20:40 PM
Linking autocad drawing |
Fri, Aug 4, 2006 at 5:57:52 AM
Recent Files |
Mon, Jul 14, 2008 at 2:31:00 PM
Update my template |
Fri, Mar 24, 2006 at 8:36:45 AM
Members: | 2115698 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
