74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> split face tool on curved extrusion
Thu, Nov 13, 2008 at 10:03:31 AM | split face tool on curved extrusion
hunterfloyd
Revit '09.  So, I've created this extrusion to act as a ceiling, and I would like to draw a grid over it, and if possible use that grid to assign different materials to different panels on the grid.  I've tried using the split face tool and it will not allow me to select the faces that are created from the extrusion.  The Red face in the image is the profile that has created the extrusion, which I can split, but I would like to split up the bottom faces for the grid.  The only option I can think of at this point is to create a bunch of different extrusions within one family, so that the edges of each act as the end of the panels on the grid.  I hope this makes sense.  Any help would be greatly appreciated.
HuntFlo
Thu, Nov 13, 2008 at 10:40:30 AM | split face tool on curved extrusion
hunterfloyd
here's an easier attachment to view.
HuntFlo
Thu, Nov 13, 2008 at 2:41:23 PM | split face tool on curved extrusion
tim123
4 Stars: 19 Votes
Click on your component and edit it.  In edit mode you can apply different materials.
Thu, Nov 13, 2008 at 3:05:22 PM | split face tool on curved extrusion
hunterfloyd
ya, i realize I'm able to edit it further in edit mode, but I'm still not able to split the face up into a grid like I want.  Here's a better image of what I'm talking about.  The red lines are where I would like the grid drawn, and within those the ability to use different materials.  thanks for the help.
HuntFlo
Thu, Nov 13, 2008 at 3:20:50 PM | split face tool on curved extrusion
tim123
4 Stars: 19 Votes
In edit mode you can also split the face - see attached image.
Thu, Nov 13, 2008 at 3:33:59 PM | split face tool on curved extrusion
hunterfloyd
well, it's not working for me in edit mode.  i have created an in place family using the create tool, and designated it a ceiling.  i drew a profile for an extrusion that i showed you earlier, and when I go to split the face in edit mode, it only allows me to select the face of the extrusion profile, and the verticle faces that are cut in the ceiling(where the lights lie) from the profile drawn.  It will not allow me to select the faces of the ceiling where I showed you I would like the grid to lie.  Thanks again for your help.
HuntFlo
Thu, Nov 13, 2008 at 4:22:30 PM | split face tool on curved extrusion
tim123
4 Stars: 19 Votes
I did the same as you, creating a compoment, designating it as a ceiling.  I then went back into edit mode, used the split face tool to split one of the faces, and then used the paint tool (bucket) to change the materials of the different faces.
Thu, Nov 13, 2008 at 4:29:52 PM | split face tool on curved extrusion
hunterfloyd
ok, this isn't going anywhere.  i'm not sure why I'm unable to do that, but I am unable to do that.  any new ideas, or reasons why that wouldn't be working for me?  thanks.
HuntFlo
Mon, Nov 17, 2008 at 4:32:39 AM | split face tool on curved extrusion
tim123
4 Stars: 19 Votes
Save the component and post it as a family.  I will check it.
Mon, Nov 17, 2008 at 4:38:21 PM | split face tool on curved extrusion
hunterfloyd
I worked around the issue by simply creating multiple extrusions whereby each seperate extrusion's end serves as the latitudinal grid line, and drawing a small kink in the extrusion profile to create the longitudinal gridline.  Too much work for what should be a very simple task, though....hmmm, it seems i'm unable to save this family as it's own family outside of the project.  it exists as a compound ceiling w/in the project, but when I try to "save to library" it can't be found.  not sure how to fix that either, but here it is in it's own project file.  thanks for your help.
HuntFlo
Mon, Nov 17, 2008 at 4:45:24 PM | split face tool on curved extrusion
hunterfloyd
HuntFlo
Mon, Nov 17, 2008 at 4:46:23 PM | split face tool on curved extrusion
hunterfloyd
HuntFlo
Mon, Nov 17, 2008 at 4:58:49 PM | split face tool on curved extrusion
#13
hunterfloyd
got it under 2mbs.  here it is.
HuntFlo
Thu, Nov 20, 2008 at 3:33:51 PM | split face tool on curved extrusion
#14
hunterfloyd
did you get anywhere with that?
HuntFlo
using split face tool on curved walls
Sat, Oct 12, 2019 at 8:21:21 AM
Using Split Face
Fri, Jul 12, 2013 at 11:00:41 AM
Can't split certain faces
Thu, Dec 6, 2012 at 6:59:32 AM
Split face aournd a corner...
Tue, Aug 25, 2009 at 2:14:23 PM
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:12 PM
Page generation time: 1.0766
