96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Family Type Constraints
Hello all, I created simple door that I wanted to add family types into it and have the option to click the drop down to change what insert to use. I constraints so that once I change the door height and width the insert will change as well. My problem is everything works fine with the first insert and once I change it to the second one "says that constraints are not satisfied? Attached is an expamle of my problem. Many thanks in advance..
Nevermind everyone I figured it out... Thanks!!
1 Posts No Rating |
I'm having the same issue with "Constraints not satisfied". How did you fix the problem?
Need more information, attaching your family would also be helpful
Type catalog errors |
Thu, Jan 19, 2012 at 2:07:18 PM
Default Constraints in window family |
Fri, May 4, 2012 at 7:13:48 PM
11
Setting Default Wall Constraints |
Fri, Jan 5, 2007 at 2:45:05 PM
Family Instant Parameter Constraints Offset |
Fri, Feb 1, 2013 at 2:41:00 PM
Can we set our own constraints and if yes how? |
Wed, Mar 16, 2005 at 7:50:00 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
