113 Users Online (112 Members):
Forums >> Revit Building >> Technical Support >> problem with ceiling in groups
3 Posts No Rating |
The accoustical ceiling tiles in a group become skewed on half of the rooms when I place a ceiling in the group, but lighting fixtures update correctly. What causes this and how can I fix it?
I have had this same problem. I experimented by locking the ceiling grid to a wall face and the grid stays consistent through the copied groups. However the problem with this scenario is that I don't want the ACT grid to be directly adjacent to the wall (I.E. I'd like to center the grid within the room). When I center the grid (unlock it from the wall) the grid is correct within the edited group and inconsistent within all the copied groups.
Did you try a dimension with a lock to the grid pattern? You can then delete the dimension if you want....
I just tried it and that method worked well. I also used tried placing reference planes and then locking the grid to the reference planes and this method also worked. So there is two solutions. Thank you for your help.
Apartment Groups - Ceiling heights |
Mon, Jul 21, 2014 at 11:11:51 AM
Groups and Phases |
Thu, Jan 29, 2015 at 10:45:27 PM
ceiling tag for mass created clg. |
Mon, Jun 2, 2008 at 12:38:04 PM
Light fixtures in groups not working properly...help! |
Fri, Mar 30, 2007 at 6:31:04 PM
How can I freeze groups? |
Thu, Sep 21, 2006 at 10:06:39 AM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
