37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adding Optional Text Field to Keynote Tag
Wed, Nov 12, 2008 at 12:27:29 PM | Adding Optional Text Field to Keynote Tag
FSinatra
I am trying to add an instance text field to the Keynote Tag that can be turned off and on as required.   I was planning on using a label, that links to "Comments" in the component, but this was not an option and there appeared to be no way to add a new parameter to the tag.  Any suggestions?
Wed, Nov 12, 2008 at 1:09:27 PM | Adding Optional Text Field to Keynote Tag
4 Stars: 202 Votes
Hi, did you use Yes/No parameter? check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=6373
Wed, Nov 12, 2008 at 1:26:02 PM | Adding Optional Text Field to Keynote Tag
Sorry - Typhoon's advice works with visibility of items in regular families but you can not do this with a keynote.  You can create a seperate tag that will read the comments.
Wed, Nov 12, 2008 at 7:42:10 PM | Adding Optional Text Field to Keynote Tag
mhans
3 Stars: 10 Votes
Do you know that you can keynote the same element 3 times? Then you can have one of those as your comment.
Motto: "No Post left behind"
Thu, Nov 13, 2008 at 8:52:48 AM | Adding Optional Text Field to Keynote Tag
You can use the user option and use any keynote anywhere.  Just have to point to a model element first.  Then move it anywhere you want. .... even out in space!
Keynote tag with text option?
Tue, Jun 17, 2008 at 1:33:16 PM
keynote categories
Fri, Aug 10, 2012 at 3:56:24 PM
Keynote Tag defaulting to Category Tag
Fri, Jul 20, 2018 at 11:20:18 AM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:41:00 AM
12
keynote tag, crooked leader
Tue, Mar 31, 2009 at 4:44:36 PM
Page generation time: 0.7529
