66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> view range issues
Wed, Nov 12, 2008 at 11:15:02 AM | view range issues
ckchambe
Hi all,
 Hopefully somene can help me out.  I'm creating four different site plans to show the projects relationship to the site at each level (its a complicated site!) The problem I'm having is that when I go to set the appropriate view range for each view.  It will only allow me to select the associated level for the "Top" of the view range.  This option for the "Cut Plane" is grayed out and the option for the "Bottom" only offers me a very limited selection. Can anyone tell me where I'm going wrong?
Thanks!
Tue, Nov 18, 2008 at 5:06:43 PM | view range issues
balbrec3
4.5 Stars: 3 Votes
I think the issue you're having is because you're trying to use the Site plan...my suggestion would be to create another level thats called "Site 2" and then adjust all of your setting for that level.  The default site level wont allow you to set a cut plane because its set to show everything without cutting so by creating a new level it should allow you all the freedom you want! Hope that helps!
Revit MEP 2012-View Range
Fri, Apr 12, 2013 at 7:22:48 AM
View Range Issues
Fri, Jun 10, 2011 at 7:13:30 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
Revit 2009 help with shaft view issues
Fri, Oct 24, 2008 at 10:41:16 AM
Plan cuts incorrectly at windows despite correct view range
Thu, Aug 6, 2009 at 9:12:23 PM
Page generation time: 0.8394
