62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to do a vertical reveal in a sweep in a curved wall?
Tue, Nov 11, 2008 at 9:57:17 AM | How to do a vertical reveal in a sweep in a curved wall?
DDSheehan
DDSheehan Avatar
Hi,
I am using Revit Architecture 2009. I was wondering if there is a way to model 1" panels with 1/4" reveals onto a curved wall.
The way I have it set up, the curved wall has sweeps to show horizontal bands of Marlite panels. When I try to model vertical reveals, they are placed in the wall substrate beyond, not the sweep material. It does not want to let me pick the curved surface of the sweep (or the wall) as a work plane to model a void mass in there.
I can't figure out another way to do this, anyone have any ideas?
Thanks!
Tue, Nov 11, 2008 at 12:42:33 PM | How to do a vertical reveal in a sweep in a curved wall?
4 Stars: 203 Votes
Hi, can you put some screenshot to figure what really are you trying to do?? But to cut the wall sweeps i think i create a "Generic model face based" with a void...
Edited on: Tue, Nov 11, 2008 at 1:26:20 PM
Tue, Nov 11, 2008 at 2:13:10 PM | How to do a vertical reveal in a sweep in a curved wall?
DDSheehan
DDSheehan Avatar
Yes, here is a screen shot. I managed to put some vertical reveals in there using solid, instead of void, extrusions in the wall sweeps, and and assigning black for the material.
Since the solids are just attached to the work plane, and aren't dependant on "cutting out" a geometry, it worked. It renders OK, but sort of avoids the problem. Still not sure if doing voids is possible.
Thu, Oct 22, 2009 at 2:04:26 PM | How to do a vertical reveal in a sweep in a curved wall?
Altus
I was able to do it by creating the reveal as a trapazoid with the smallest side in the wall and the largest side about an 1" 'outside' of the wall.  That was for a convex curve.  I imaging you would have to make the smallest side of the trapazoid on the outside for a concave wall (but I haven't tried that yet).
Vertical reveal spacing in a curved wall
Mon, Feb 21, 2005 at 9:08:18 PM
vertical wall reveal troubles
Wed, May 6, 2009 at 3:22:52 PM
Vertical reveals to angle wall end
Mon, May 11, 2009 at 11:36:00 AM
Vertical Wall Reveals not cutting sweep
Wed, Nov 8, 2006 at 9:23:11 AM
Wall Sweep - Reveal; How to dimension to reveal centerline? (RAC 2009)
Wed, Apr 14, 2010 at 2:35:31 PM
Page generation time: 1.5472
