70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Yes/No Conditional on No/Yes
Tue, Nov 11, 2008 at 9:45:28 AM | Yes/No Conditional on No/Yes
JRMello
I am intersted in making one item in a family visible only if another item is not visible. This seems like it would be a relatively easy formula, but I can't figure out how to organize it or even if Revit would allow it.
RAC2009
Tue, Nov 11, 2008 at 10:05:06 AM | Yes/No Conditional on No/Yes
coreed
coreed Avatar
4 Stars: 16 Votes
maybe this link and info will help
http://www.revitcity.com/forums.php?action=viewthread&thread_id=13566
From a previous post by Tom Dorner
Below is the Revit help file which explains it pretty well.
You can use conditional statements in formulas to define actions in a family that depend on the state of other parameters. With conditional statements, the software enters values for a parameter based on whether a specified condition is satisfied. Conditional statements are useful in certain circumstances; however, they make families more complex and should be used only when necessary.
For most type parameters, conditional statements are unnecessary, because the type parameter itself is like a conditional statement: If this is the type, then set this parameter to a specified value. Instance parameters are a more productive place to use conditional statements, particularly when they are used to set a parameter that does not vary continuously.
Syntax for Conditional Statements
A conditional statement uses this structure: IF (<condition>, <result-if-true>, <result-if-false>
This means that the values entered for the parameter depend on whether the condition is satisfied (true) or not satisfied (false). If the condition is true, the software returns the true value. If the condition is false, it returns the false value.
Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters. You can use the following comparisons in a condition: <, >, =. You can also use Boolean operators with a conditional statement: AND, OR, NOT. Currently, <= and >= are not implemented. To express such a comparison, you can use a logical NOT. For example, a<=b can be entered as NOT(a>b).
The following are sample formulas that use conditional statements.
Simple IF: =IF (Length < 3000mm, 200mm, 300mm)
IF with a text parameter: =IF (Length > 35', "String1", "String2&rdquo
IF with logical AND: =IF ( AND (x = 1 , y = 2), 8 , 3 )
IF with logical OR: =IF ( OR ( A = 1 , B = 3 ) , 8 , 3 )
Embedded IF statements: =IF ( Length < 35' , 2' 6" , IF ( Length < 45' , 3' , IF ( Length < 55' , 5' , 8' ) ) )
IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
-----------------------------------Tom www.reviteer.com http://blog.reviteer.com
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Nov 11, 2008 at 12:21:07 PM | Yes/No Conditional on No/Yes
JRMello
It took a bit of playing around, but I figured it out. I tried   ParameterA = NOT ParameterB  but got a message about "NOT ParameterB is an invalid parameter name, check caps etc" but it worked when I put parenthesis around ParameterB so the formula reads  ParameterA = not(ParameterB)
Now I have the problem that this formula doesn't allow you to use the check box for ParameterA, but I'll deal.
Thu, Jun 27, 2013 at 9:58:48 AM
Schedule Line Shading - Revit 2009
Fri, Oct 1, 2010 at 3:53:11 PM
Conditional statements in families.
Wed, May 14, 2008 at 4:27:35 PM
conditional formatting yes no parameters
Tue, Oct 28, 2008 at 9:58:55 AM
Conditional statemnent for negative value of degree celcius not working
Sun, Jan 16, 2011 at 11:01:11 PM
Page generation time: 0.1851
