79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stone Corner and Window Trim in Masonry Wall
Tue, Nov 11, 2008 at 9:37:45 AM | Stone Corner and Window Trim in Masonry Wall
scully77
Hey Just wondering if anyone knows the easiest way to show "keyed" stone trim around windows or coins at the corner of masonry buildings. Has anyone done this?
Tue, Nov 11, 2008 at 1:27:50 PM | Stone Corner and Window Trim in Masonry Wall
4 Stars: 202 Votes
Like what?
Tue, Nov 11, 2008 at 2:06:19 PM | Stone Corner and Window Trim in Masonry Wall
mthurnauer
3 Stars: 2 Votes
I would make a generic family model of the corner keystones and then create a line-based family.  Load the model of the keystone into the line based family.  Then create an array of the keystone component and create a parameter for the number items in the array (call it KEYSTONE NUMBER).  You will want to make a formula for the KEYSTONE NUMBER parameter.  Let's say that the keystones are 2 feet apart.  The forumula will then be KEYSTONE NUMBE = Length/2'.  When you load this family into your project, you will be able to draw a line up the corner of the building and the detail will repeat automatically.
Thu, Jul 30, 2015 at 12:29:38 AM | Stone Corner and Window Trim in Masonry Wall
jacobreeva
There are specific stuff for this to use and ther geometry should also be perfect, otherwise a small .cm in excess or ommited matters a lot.
"works for http://caldwells.com/ as door evaluator"
Stone wall covers door and window trim?
Thu, Jan 3, 2008 at 8:50:33 AM
Arched Window in Masonry Wall
Mon, Mar 4, 2013 at 5:28:04 AM
Arched window with stone arch above it? How to do it?
Wed, Apr 13, 2005 at 2:22:58 PM
Wall Sweep only cuts out window not trim
Mon, Aug 18, 2014 at 10:34:17 PM
Anyone? Why does stone render wierd here. Same wall on each side of corner
Mon, Nov 17, 2008 at 9:52:13 AM
Page generation time: 0.8091
