39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> FAMILY NOT GOING TO ENDS OF WINDOW PANEL
Mon, Nov 10, 2008 at 4:02:38 PM | FAMILY NOT GOING TO ENDS OF WINDOW PANEL
mmadams2
I created a curtain wall panel family that is a louvered window. When I try to use it in my project it doesnt extend all the way to the right side of the panel and also goes above the top of the panel!!? Please help i'm sure it's something simple I'm doing wrong, i'm new to families and I did this following a tutorial.
Fri, Nov 14, 2008 at 9:12:46 PM | FAMILY NOT GOING TO ENDS OF WINDOW PANEL
balbrec3
4.5 Stars: 3 Votes
When you're creating the window pane or panel or whatever it is that seems to not be attaching right try to constrain the edges you want to the edges they attach to otherwise they'll stay the same height as they were when you created it in the family.  So if you have a curtain wall pane and you want to attach it to the top of the system create the sketch and then constrain the sketch lines to the top of the system....that should fix your problem.  Hope that helps!
Window Family - Keeping an Arrow Symbol Centered within a Glass Panel
Fri, Nov 18, 2011 at 1:20:30 AM
Multi Panel Sliding door that is actually a Window Family
Fri, Feb 20, 2009 at 7:22:04 AM
Storefront Window Panel Dynamic Length?
Fri, Jun 30, 2006 at 1:43:15 PM
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
Wood Screen - Curtain Panel
Sat, Jan 10, 2015 at 1:44:00 AM
Page generation time: 2.1148
