43 Users Online (42 Members):
Forums >> Revit Building >> Tips & Tricks >> Curved Roofs.... a different sort of curve
12 Posts No Rating |
I have been trying to model a curved roof in Revit and getting nowhere. The roof itself is a simple pitch, however the building itself curves around and I want the roof to do so (like a curve on a cone). In ADT I would draw the profile and then extrude this along a curved path. The tutorials seem to be focussing on roofs that curve in themselves but in plan are straight. This one seems a different animal.
I am thinking single slope curved... not standard gables following a curved plan
Any ideas would be much appreciated :-)
Post edited on 2005-05-14 17:27:05
28 Posts No Rating |
Could you build the shape you are trying to achieve as a mass model and then do a roof by face? I thnk it should work. It is a fun little trick I just recently learned.
HTH
Vanessa
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Why not just sketch the roof by footprint in plan, and make the arc a slope defining line? This will give you a conical shaped roof.
2 Posts No Rating |
You have a couple of choices with this. Either do as you explained the ADT approach and build an in-place family, or use a footprint roof and slope define the curve. Make sure you go into the properties of the curve and set the facets to zero, otherwise you will see a segmented roof. This functionality only came in with release 8 so if you have an older release it won't work.
25 Posts No Rating |
hi there i wanted to create a curved cileing i knwo i can create it by massing but i cant soo yess (typhoon) one more hiccup on ma side replies would be greatly appreciated.... muf
Curved Stair Question |
Mon, May 7, 2007 at 2:10:41 PM
Curved stair and railing issue |
Tue, Oct 4, 2016 at 1:32:22 PM
Curve Walls |
Mon, Dec 22, 2008 at 6:13:27 PM
Making Curve Ladder Trusses |
Tue, Jan 16, 2018 at 8:21:53 AM
Curved Beams |
Wed, Jan 6, 2010 at 1:49:03 PM
Members: | 2022374 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
