42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> What is your standard for anotating levels
Mon, Nov 10, 2008 at 10:57:05 AM | What is your standard for anotating levels
everist
3 Stars: 2 Votes
Using Revit 2009
I am considering several options for anotating levels in wall sections and building sections and would like to understand what others are doing. I have listed the options in the order of preference. I.E. I would ideally like to use number 1.
Option 1:  Use the level identifications to anotate the levels. How do you adjust the text size of the level identification? Its just way to big out of the box.
Option 2:  Use the Spot Dimension tool. This tool is handy becasue you can choose to dimension an elevation relative to other levels in the project. However, there is not an obvious way to add a title to the level. Refer to the attached pdf.
Option 3:  Use a dumb level symbol where you can enter text and the name of the levels independet of any data available in the program.
Mon, Nov 10, 2008 at 12:40:39 PM | What is your standard for anotating levels
3.5 Stars: 395 Votes
Do option 1 and make your own level head - sized as you want it.
Detailing & Anotating in a view. Can you lock the 3D elements before you start
Mon, Sep 16, 2013 at 1:23:28 PM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
Page generation time: 0.3472
