100 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Murox structural wall system
Mon, Nov 10, 2008 at 8:22:21 AM | Murox structural wall system
Murox
Murox Avatar
Hello,Our compagny are creating a special structural wall system and I have a problem concerning the beam at head of the pannel. I have many parameters in the family, and all is going all right in the family but when I import it into a project and I change the heigth (parameters : Hauteur à gauche & Hauteur à droite) the beam doesen't connect correctly. I think there is a problem with "host" detection but I dont' know how to fix it. Tank you for your replies !
Note : This is a generic model familly to apply on a wall. Test it into a project tand change the values to view the problem with the beams.
Edited on: Wed, Nov 12, 2008 at 3:12:52 PM
Carl Veillette
Nothing is impossible ...
Sun, Nov 16, 2008 at 3:25:57 PM | Murox structural wall system
Murox
Murox Avatar
Forget about that I found the solution ....
Carl Veillette
Sun, Nov 16, 2008 at 3:26:43 PM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:44 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:52 PM
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:03 AM
structural walls copied from arch
Fri, Aug 21, 2009 at 6:49:56 AM
Page generation time: 1.5276
