1 Posts No Rating |
So i'm a student really new to Revit. I got the entire project done. The problem i'm having is I want to duplicate the entire house and offset each one so that it goes downhill to form row houses. I tried grouping the entire house but mullions and the solid sweep blends i used to create my roof and walls keeps getting deleted and fatal errors seem to be happing. What are the best ways to go about duplicating my house beside grouping it. Is there a function where i can "flatten" my project before i copy and move it so pieces of it aren't deleted?
Hi, did you try the "IMPORT-LINK-REVIT"? If i was you, i create another file (save as...) then open that 2 model and delete what i don't want, i leave only that "entire house" , save and exitand close that file, then in the original project go to "File-Import/Link-Revit", pick in the 2 model and open, after the "new" house are insert in the model you can place them and adjust in elevation and so one, after the model are in the right place and everything it's ok, pick in the "House" and in menu bar youhave the "BIND" button, after this, your model it's like a group and you can ungroup if you want...
