23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Section Cuts
Sun, Nov 9, 2008 at 2:01:05 AM | Section Cuts
jsneed665
I am also trying to take a section sight through my site.  I drew it through my street so that it would show a street elevation of the buildings along the street.  I set the far clip right behind the facades of all the buildings.  When I look at the section cut however, other buildings on the site are showing up in it that are not a part of where I am taking the cut.  I have tried many settings in the properties box such as different cliping planes etc.  This can't be how it is supposed to look.  Any advice?  THank You,
Jen
Using revit architecture 2009
Sun, Nov 9, 2008 at 3:43:51 AM | Section Cuts
tim123
4 Stars: 19 Votes
Click on the elevation symbol in the plan view and check the position of the dotted line showing the view range.  Is the 'Far Clipping' on in the view properties?
Sun, Nov 9, 2008 at 8:18:41 AM | Section Cuts
jsneed665
I have the dotted line right behind the facades of the buildings along my street.  From the section cut to the dotted line is just the street and those buildings.  I have no Idea why other buildings are showing up between the "camera" and those buildings because they are not there.
Sun, Nov 9, 2008 at 8:52:34 AM | Section Cuts
tim123
4 Stars: 19 Votes
Do you have a link in your model (or a dwg from which you traced the elevations)?   This could be intefering with it.
Sun, Nov 9, 2008 at 10:55:45 AM | Section Cuts
jsneed665
The buildings on the sight are linked in from a sketchup model.  But they are all in the place that they should be.  In all views there is nothing that shouldnt be there except in the sections.
Mon, Nov 10, 2008 at 7:21:11 AM | Section Cuts
Is your sketchup model one model?
What did you import it as?
From REVIT's help -
 I think your answer is here.  You have one import and if any of it ';s in view (or cut), it all is.
Mon, Nov 10, 2008 at 9:21:08 AM | Section Cuts
jsneed665
I do not belive I did.  That sounds great I will try that and let you know if it works.
Section cuts WAAY too deep!
Tue, Jun 7, 2011 at 5:34:56 AM
Rouge sections cuts
Wed, May 2, 2012 at 4:07:33 PM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:45:00 AM
Detail Cuts
Wed, May 3, 2006 at 5:03:49 PM
Phases and Section Cuts
Thu, Mar 19, 2009 at 9:49:28 AM
Page generation time: 0.4496
