69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Host Sweep won't cut thru Windows
Sun, Nov 9, 2008 at 12:25:46 AM | Host Sweep won't cut thru Windows
ashleyjoyce
I'm using the window sweep to create a weatherboard profile around my walls. however, the sweep will cut thru doors but not my windows. I saw another post showing it could be done. In the constraints I've checked "cut of inserts" but that doesn't seem to work.
Any trick to this?
Sun, Nov 9, 2008 at 5:39:52 AM | Host Sweep won't cut thru Windows
4 Stars: 202 Votes
Can you post some images to check?
Sun, Nov 9, 2008 at 6:29:55 AM | Host Sweep won't cut thru Windows
ashleyjoyce
I got around the problem by, splitting & Joining, whilst adding multiple sweeps to the wall. Its not ideal but I guess it works. I had see in another post, where someone was able to have the Host sweep cut thru the windows not just the doors. Is this possible or not?
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Void Sweep won't cut extrusion
Fri, Aug 24, 2012 at 3:02:42 PM
Wall host does not cut when meeting with windows
Wed, Apr 26, 2006 at 6:12:56 PM
Wall Sweep Doesn't Completely cut
Tue, Jun 19, 2018 at 10:47:01 AM
Void Won't Cut Extrusion
Wed, Feb 13, 2013 at 11:04:26 AM
Page generation time: 1.3950
