Forums >> Revit Building >> Technical Support >> Spot Lighting Beam Spread
when creating a new spot lighting fixture family the following 2 parameters can be specified: spot beam angle spot spread angle They don't seem to actually affect the light that is cast in a rendering, is that true Are they just info for a schedule?
The standard revit spotlights do adjust if you change these parameters - did you create yur own?
Open that family, Flex those parameters and check if they change the light...
what do you mean by "flex". if I change the value under the "family type" dialog, there is no change in the beam spread in a redering.
What you just did is "FLEX" the family, is testing the family to see if all work, in your case there aren't any change in model when you change the parameters (flex the family), there are something wrong with your family, you must edit and check what is wrong in the model... did you create that family light by "Lighting Fixture Ceiling based"??
no, it is an generic family, so that I can vary the elevation of it. It really does not appear after many tries of varying the light's position relative to other solid objects (cabinets adn walls) and its elevation that flexing those parameters affects that spread of the light in the rendering. I wish it did.
Hi again, see this: http://screencast.com/t/Qu0Hq1MG5
excellent, if you were any more clear, you'd disappear! Thanks, I will try it.
Very good explanation Typhoon.
send a feedback to know if it work and solve your problem...
warehouse lighting |
Mon, Nov 14, 2011 at 11:02:32 AM
Steel Beam spot elevation |
Wed, May 7, 2008 at 6:26:18 PM
Beam wont show, Spot slope not Accurate and Twin windows |
Tue, Jul 14, 2015 at 12:41:46 PM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:17 AM
Looking for auditorium/stage lighting fixtures for interior rendering.... |
Wed, Mar 30, 2011 at 5:12:17 PM
Members: | 2114720 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
