69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface pattern wont align
Sat, Nov 8, 2008 at 4:05:34 PM | Surface pattern wont align
jsneed665
I am using revit architecture 2009.  I have a curtain wall where I made the top panels solid metal panel with a 5' grid.  The grid lines need to match the mullions below which are 5' OC however the pattern automatically centered on the panel.
 I tried using the align command but the pattern didnt move.  I also tried selecting the pattern and using the arrow keys and move command to shift the pattern but neither worked.
Any suggestions?
Sun, Nov 9, 2008 at 3:16:04 AM | Surface pattern wont align
tim123
4 Stars: 19 Votes
Your pattern needs to be a model pattern.  If you want ot move the lines of the pattern then you need to go into edit mode of the panel and then the pattern is adjustable.
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
surface patern not aligning
Fri, Jul 20, 2007 at 9:38:40 AM
Revit wont align siding
Fri, Dec 2, 2011 at 8:46:33 AM
Align painted surface
Fri, Jul 22, 2016 at 1:28:22 PM
Page generation time: 0.4835
