84 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> Sheet Boundaries
32 Posts No Rating |
Is there a way to show a sheet's boundaries? I'm sure there's a simple thing I just don't know how to do. Would like to know where I can place things on my sheet before they are floating in the ether. Thanks in advance!
![3.5 Stars: 11 Votes](/images/stars_3.5.gif) |
press F1 you should probebly make a titleblock to import into your sheet ( or import a standard one )
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
We use invisible lines on our titleblock sheets to show the printable area. You can see them all the time but after placing a view, you can roll-over the sheet and then see the relationship of the view to the boundry.
F1 just goes to Help...which didn't help, unfortunately. I suppose we need to outline the page in our title block xref so that that is imported ni with the titleblock?
Why are you using an import? This should be a REVIT sheet family. It needs to be parametric and the edge of the paper will show up all the time when you use it.
I'll have to talk to the guys here that set it up. Don't know why we're xreffing in our CAD titleblock.
lol dont import a cad title block as a xref, you can do so much more with a titelblock familie and 'project parameters'
Edited on: Fri, Nov 7, 2008 at 10:16:41 AM
peace is the path."
Mahatma Gandhi.
I have a feeling this was a quick-needed thing before we were able to set up the Revit family for it. Thanks for all your help, guys!
Phantom Area Boundaries |
Tue, Sep 29, 2009 at 1:12:12 PM
Any way to automaticaly find room boundaries to make finishing floor? |
Wed, Sep 17, 2014 at 8:13:11 AM
Room boundaries woun't properly display |
Tue, May 15, 2018 at 3:08:14 AM
Room Boundaries limited? |
Fri, Jan 30, 2015 at 5:19:55 PM
editing room boundaries [ 1 2 ] |
Thu, Oct 5, 2017 at 7:21:19 AM
16
Members: | 2022486 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
