48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Add Section Lines to a 3D View
Thu, Nov 6, 2008 at 8:25:43 AM | Add Section Lines to a 3D View
siwilks200
How do i add section lines to a 3D view, i dont need the actual sections just the lines indicating where i have taken sections through on the sheet.
Thu, Nov 6, 2008 at 9:54:02 AM | Add Section Lines to a 3D View
Although I try to keep everything model based if I can, in this instance, I would just draw them in "paper space".  Overtop of your view.
Thu, Nov 6, 2008 at 10:10:31 AM | Add Section Lines to a 3D View
siwilks200
yes, i looked into that but once i am on the sheet, the line icon is greyed out and i cant select it
Thu, Nov 6, 2008 at 10:43:40 AM | Add Section Lines to a 3D View
tim123
4 Stars: 19 Votes
Go to the drafting menu.
Thu, Nov 6, 2008 at 10:50:23 AM | Add Section Lines to a 3D View
siwilks200
a ha. most items are greyed out but i do have 'detail lines' available. cheers
Column grid lines disapear in one section view.
Thu, Aug 2, 2007 at 5:00:18 PM
Adding gaps to jogged section lines
Tue, Sep 3, 2013 at 10:08:41 AM
Lines disappearing in elevation/section view.
Thu, May 16, 2013 at 7:31:33 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:24 PM
Tag for View name & View scale on section views
Thu, Nov 26, 2009 at 4:45:38 AM
Page generation time: 2.0077
