Forums >> Revit Building >> Technical Support >> Mitering cornice family
Need some help. I've created a wall based family of a two member cornice that works pretty well except that I dont;t know how to make it miter and return at a 90degree angle to the house. Also, I'm not able to run it around an outside corner. Otherwise, I like it just fine. Any ideas? I've asked my contacts at my Autodesk reseller and the suggested having it nested in part of a wall assembly. That won't work though, as I am creating this for exterior use and need to be able to adjust it to meet the fascia. If the rafters need to rest on a 2' kneewall, building the cornice as suggested by the reseller won't work. It needs to have the flexibility to move up and down. Hopefully the attachment will show the family I created. Thanks all!
Hi, see the video and give a feedback...: http://screencast.com/t/e2fJwU9nS
Typhoon, Thanks so much for posting the video. I really can't thank you enough for taking the time to put that together. Once I get my kids in bed, I'll spend some time with it and let you know how it works. If I wanted to create some custom sweep profiles, what would you recommend to be the best method? Don
I would make a profile family and then make a wall sweep. Wall sweep is hosted by the wall but not part of the wall. Let me know if you need more detail.
----------------------------------- BallewDesigns.com |
Hi, like Robin said, create your "profiles (2D)" in "Metric/Imperial Profile" and save them all in one folder "Profiles" "Metric/Imperial Library",in the Profile-family if you go to Settings-Family Category you can change the family category, take a look on this, then you have the two choises i post in video yesterday...
Typhoon & Robin, Thanks a ton for your help. After following your suggestions, I was able to easily create the cornice. See attached. It's a typical multi-member cornice used here in Richmond. I also included a 1x8 fascia so that I could tie to the roof easily. I hope you like it. Thanks.
You forgot to attach...
Connectivity problems today. Try it now.
Nice, one more type for my profiles, thanks...
Typhoon, Try this one. I think you'll like it. You can adjust it away from the wall and miter it at 90 dgrees to return it. It's a nice, simple way to create a finished porch entablature (Tuscan Order for a 10" Column). Enjoy.
Thanks CARRIAGE, i think you must put here this family in "Upload content" to the others....
In place family cornice |
Tue, Jul 15, 2008 at 7:14:06 AM
Cornice on exterior wall disappears when I place window 2' above it?! |
Mon, Nov 28, 2011 at 2:22:08 PM
how to add cornice to the roof ? |
Tue, Aug 22, 2017 at 3:18:00 AM
Advice - Wall Cornice |
Fri, Feb 3, 2012 at 12:05:52 PM
Mitering curtain wall panels |
Wed, Dec 26, 2007 at 9:11:56 AM
Members: | 2100548 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
