Forums >> Revit Building >> Technical Support >> Display error
HI, Anybody facing this problem. After few minutes my revit screen changes(see attached snapshot) It seems to be a graphic card problem but not sure .. Thanks in advance Ramesh Sharma
Now on the implementation stage.... |
is probably has to do with your OpenGL Hardware. try turning it off and see what happens
Thnx coreed I have tried that option many times but no improvement. Is revit reinstallation is a solution? Cheers
it's one that has solved many of my problems in the past. also make sure you have all the latest drivers for your grahics card installed.
Instlling the latest version of graphic card solves the problem. Cheers
Print Error "Display Error" |
Tue, Dec 20, 2005 at 5:04:35 PM
Display error: An error has occurred while drawing the contents of this window. |
Wed, Aug 24, 2011 at 6:21:15 PM
Display error |
Tue, Jun 21, 2011 at 5:29:44 PM
Level head text - display in elevation view |
Thu, Feb 26, 2009 at 4:36:16 PM
Revit Building Display Error - prior to crash |
Fri, Apr 2, 2021 at 2:39:00 PM
Members: | 2109603 | Objects: | 23184 | Forum Posts: | 152302 | Job Listings: | 3 |
