50 Users Online (49 Members):
Forums >> Community >> Newbies >> Scaling?
8 Posts No Rating |
Okay so I plans for this building, and then I had to scale it down to fit the size of paper that I need to print at. But how do I scale the text and door/window symbols too? this is my problem: http://img45.imageshack.us/img45/1858/scaleswi9.jpg
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
Try print to fit. Do not scale it is Revit. Set up the Sheet for Full size or what ever looks good. The print it to fit on what ever paper you want.
----------------------------------- BallewDesigns.com |
8 Posts No Rating |
how would I go about doing that?
See the attached image. To get to print setup goto File rint Setup. You can also goto it from the Print rint Setup dialog.
8 Posts No Rating |
I need a title block to print it on should i just edit it and make it larger?
Maybe I wasn't clear. Set up the sheet however you want it to look. Full size. Title Block, text, Dimensions, what ever. Then print it to "Fit" on what ever paper you want. It is really exactly the same thing as printing to "Fit" or "window" in any program. I do mini check sets on 11x17 all the time.
Scaling Family or component- similar to scaling jpeg |
Mon, May 12, 2014 at 2:44:09 PM
Scaling furniture |
Sat, Nov 27, 2010 at 8:16:59 AM
Scaling |
Tue, Apr 24, 2007 at 1:08:57 PM
SCALING JPEGS FOR RENDER SCENES |
Mon, Oct 10, 2005 at 3:53:23 AM
Decal Boarder and material scaling |
Wed, Nov 27, 2013 at 1:37:16 PM
Members: | 2017260 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
