106 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Best Software to Create Presentation Floor Plans
Wed, Nov 5, 2008 at 1:50:58 AM | Best Software to Create Presentation Floor Plans
robpap
4.5 Stars: 7 Votes
Hi everyone.
 I have been asked by a large architectural firm to create presentation floor plans to go along with my presentation images created in revit 2009.
 I have tried Revit and autodesk impressions to create the floor plans, but neither of them can produce the image that they require.
I have attached an image of what the floor plan should look like.( the scan quality is not great, but the general idea of the furniture, cars. etc) Would any one be able to let me know which software they use or would be able to create floor plans like this.
 Thanks to anyone who could possible help.
 Rob
Rob Papworth
| ( 0407-231-889 |  | @ rob@rpimages.com.au | | www.rpimages.com.au|
Wed, Nov 5, 2008 at 3:43:24 AM | Best Software to Create Presentation Floor Plans
4 Stars: 202 Votes
Hi, it seams like "AllPlan" or "Artlantis"....
Wed, Nov 5, 2008 at 7:39:24 AM | Best Software to Create Presentation Floor Plans
coreed
coreed Avatar
4 Stars: 16 Votes
That would be Photoshop
checkout this site
http://artchitect.com/indexenglish.htm
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Nov 5, 2008 at 10:11:26 AM | Best Software to Create Presentation Floor Plans
cbcarch
The quality you are looking for can be achived in Revit and/or 3dsMax.
You can try these two methods:
 1. set up a camera looking straight down--"orient camera to View--top.
set up lighting, materials for floors, carpet, furniture, etc. in Revit.
Render the view in Revit/Mental Ray.
2. Export the Revit file, from the 3d camera view, via FBX and import into 3dsMax 2009,
add lighting, tweak materials, and render the view.
cheers...
Thu, Nov 6, 2008 at 7:42:09 AM | Best Software to Create Presentation Floor Plans
tim123
4 Stars: 19 Votes
See the attached floor plan done in Revit only.  Its fairly low res - the original was much higher.
Fri, Nov 7, 2008 at 4:29:41 PM | Best Software to Create Presentation Floor Plans
mthurnauer
3 Stars: 2 Votes
I would personally choose to do that in Illustrator over photoshop.  You would create a layer that is the closed polyline of tye walls with a solid fill and then add a drop shadow effect to it.  The furniture would be done in a similar way of createing closed lines with gradiated fills and slight drop shadows to make it appear 3d.
Fri, Apr 30, 2010 at 12:56:48 AM | Best Software to Create Presentation Floor Plans
carrucha75
carrucha75 Avatar
4 Stars: 24 Votes
Well I would say RAC 2011 now can do it, but you can try Chief Architect X2 it is a good one click here to see the info:
http://www.chiefarchitect.com/shop/pricing.html Cya!
Not Sure What Revit Can Do?... Find it OUT!!!
Imagination is more important than knowledge...” -Albert Einstein
Wall infills for plans (presentation purposes)
Tue, Aug 25, 2009 at 8:17:23 AM
Best Software to do a Walkthrough Prentation for MEP (CSD) model
Mon, Jan 13, 2014 at 7:49:55 AM
Thu, Mar 25, 2010 at 11:35:28 AM
presentation drawings
Sat, Dec 29, 2012 at 10:41:39 AM
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:22 PM
12
Page generation time: 4.0710
